Dewi Bungsu
Active member
Hi,
I'm currently working on a battery that can make me switch the battery on RED Cam without having to turn off the camera.
I bought a Power Tap Cable from Anton Bauer so whenever I want to change the battery, I connect the Power Tap receptacle
to the battery plate while the 4 pin XLR will be connected to a 12V battery.
The problem is...it doesn't work
We connect the Power Tap cable to the battery plate and the 12V battery, then we took off
the empty battery from the battery plate and the result is the camera is still on. However, it only works until that stage. When
we attached a fully charged battery to the plate, what happened is the camera suddenly turned off.
So I'm thinking that maybe I need some kind of a switcher that can switch the flow of the battery? I don't know, I'm kinda hopeless
now. Can anyone help me, please?
I know that there is Switronix and Action Products hot swap that can easily doing this, but price are too expensive for me and
i am wondering if I can have this as custom-make.
Hopefully you can help me and any thoughts would be very appreciated.
Nanda
Nanda
