The lens mounts should be the same on Scarlet Cinema and the Epic line. It's all the DSMC system.
Digi primes are 3chip lenses you'll need optical compensation to correct the color dispersion otherwise there will be major color fringing
2/3 cinema with 100mm red pro prime
http://reduser.net/forum/showthread.php?26869-IzzY-2-3rds-Scarlet-with-100mm-RED-PRO-PRIME&
That is in march 09 though...Scarlet has completely been redesigned since then right? I dunno, looking at that chart that Paul posted, a PL lens or a canon lens on a scarlet cinema would only have the benefit of filming wild life from afar. lol.
Most modern Super 16mm glass is PL mount. Older 16mm Arri standard and B-mount lenses adapt to PL very easily. I also have PL adapters for my C-mount lenses too. PL is a very versatile proven mount for cine glass of all types, so is as essential for Scarlet Cinema as for Epic.
No the basic physical design has not changed much since '09, just the electronics. More beef. HDRx, and Redcode 100 maximum data rates instead of Redcode 42. Who knows what else.
