Jannard
Red Leader
- Dec 28, 2006
There is a very powerful tool in REDCINE-X called Looks. You can create a look by adjusting just about any setting and saving/naming it in the Look Preset folder. Or you can right click in that box and import one from your friends. After you have created or imported a Look, go to Look Setup and de-select anything you don't want to carry over to your clips... like ISO, Kelvin and Tint.
This is a standard one I have created and apply to just about every one of my clips as a starting point. It is based on REDcolor2 and REDlogFilm. From here I adjust Shadow (or Lift) if the blacks need adjustment... and usually saturation if needed. You can adjust just about anything necessary to work with a particular setup and then save that Look for similar files. You can also export a Look back to the camera if you want.
Jim
Jim
