MikeHedge
- Dec 28, 2006
- Age
- 44
- Los Angeles, CA
- www.mikehedge.com
Anyone rockin' this setup? Seems ideal for the field/battle... etc...
You have an eyeball located in the top of your chest?
Collar-bone cam! LOL!
Well, to be fair, in this render the version of the Bomb EVF was the one that had the "folding-riser" mechanasim built in to it's base. You can see the adjustment thmbscrews and the two "flanges" integrated in to the bottom of the EVF in the picture.
Right now it's sitting in it's "folded" form, but the plan was that you could position that style of EVF quite a bit higher just by using the buit in mechanism. This didn't show it here raised up, but in another render they did, IIRC.
-sc
That's interesting. Would the mechnism really rise that much?
But it's interesting to think about the idea of hanging the camera from the top rails rather than sitting it on lower rails. The low COG would have some advantages. But there would have to be some kind of handle attachment point. Just holding the brain or side handle wouldn't work very well. Once you got that worked out, the evf mounting problem would be easily solved -- even if you just used an arm.
