- Moderator
- #1
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
I picked this up from my friends at Schneider Optics, it's a modification they do to the Lee filter holder system that allows it to securely hold two 4x4 or 4x5.65 4mm glass filters instead of the usual Lee 2mm. I tested it with the included 77mm WA attachment ring and it only vignettes ever so slightly in the very corners on 5K full frame and 2:1 and it's really only visible stopped down to 5.6 or beyond. Also just zooming slightly to about 11.75mm eliminates it completely. 5K 2.40 has no vignetting at all even at 11mm as I would imagine 1.85 and all the other resolutions wouldn't.
It really is quite an elegant and affordable way to use your existing 4x5 filters on the 11-16, you can even use grads in the verticle position but I'd probably paper-tape the filters just to be safe.
I think Schneider is selling these for around $150
