Brandon Danowski
New member
- Mar 25, 2011
I've used the RED Rocket (RR) in the past without any issues. Now, the card has been moved to a new box (both of them we're MacPros) and it seems that something had gone awry.
I'm running REDCINE-X_build_356 and the RR with Driver: 1.3.5.0 and Firmware: 1.1.10.2. What is happening (or rather NOT happening), is that I can open the .r3d files in my browser and move them to my bin but when I drag them to my viewer, it stays black. I can't play the video, scrub or anything. It WILL however, play the audio from the clip (and it will say at the bottom of the viewer that it's playing back around '1 fps').
What's even more peculiar is that if the clip has a meta data look applied to it, I can drag it to the viewer (still with no video showing up when I do so), then reset the clip to default in the 'Look Control' panel. When I do this, the thumbnail in my bin will actually reflect the changes I made in the 'Look Control' panel but I still can't see any video.
I'v tried every conceivable combination of REDCINE-X builds and RR Driver/Firmware updates to no avail; this includes going back to the previous release of REDCINE-X and RR Drivers/Firmware. And yes, I'm sure I installed the Driver/Firmware in the correct way/order. I've only found one other online who's had a similar issue, but that thread didn't lead to a solution.
ANY help would be amazing! Thanks!
