Erik Widding
REDuser Sponsor
There have been various comments made about the knob... except for tension issue, which we are already have a fix for, these comments have been mostly positive.
It goes without saying (or at least it should) that there will be a rail mount, and a single witness mark on that rail mount. The rail mount, and the knob will be removable from the spindle/housing for integration into underwater housings.
I met Finner for the first time at the REDuser event - and once again - the topic of whips and speed cranks. I want to make sure we aren't making any short-sighted decisions. We will be contracting for the molds (approximately a $5K expense) in the next few days.
I will start this off by saying, for a $300 accessory there is a limit to how far we will go to match the exact details of a chrosizel...
As far as the whip goes, I am satisfied that a cable and second off camera knob is a reasonable, though not perfect, compromise.
Finner raised the topic of the speed crank. What purpose does this serve if we can map the entire range (or any subrange) of focus throw to a single turn of the knob?
Evin (or was it Brook?) mentioned that he is used to FF knobs being a little taller. Is this desirable? If so, how tall? We are already the same diameter as an Arri, and accept Arri marking disks.
Finner also raised the topic of additional witness marks that are both movable and tactile. How many people see this as important, and would see it as important enough to buy a more expensive knob? (don't worry there is still going to be a $300 knob.)
When a lens is calibrated, the mount will go out and look for knobs. The default will be to map the first knob in the chain to focus, and the second to iris. Later software will allow this to be user configurable. Any objections to this mode as the default?
We have three push buttons on the mount, (T)op, (M)iddle and (B)ottom. At the demo, the following button combinations were assigned:
Changing the "gearing" of the knob was a common topic of discussion. Maybe we change the interface to the following:
Please discuss/propose what the default should be. Want to have something that will work out of the box before remote controls, pda software, etc, are ready.
- T+B: iris open to widest stop
- M: calibrate focus/knob, one turn equals full range
- T: iris open 1/2 stop
- B: iris close 1/2 stop
- ReplaceLens: calibrate focus/knob, one turn equals full range
- M(2 seconds): recalibrate all knobs to respective axiis, one turn equals full range
- M+T+KnobRotate: set far focus stop, remap knob range
- M+B+KnobRotate: set near focus stop, remap knob range
- ReplaceLens: calibrate all knobs to respective axiis, one turn equals full range
