Craig Parkes
What is the purpose of this rig? To turn the camera on its side?
When would someone need a motor controlled rig like this to tilt the camera, as opposed to a tripod head that tilts?
It's not motor controlled.
Would This be compatible with a Steadicam stage - nice for turning a rig sideways and drifting across a pool table or into a car interior!
Probably not the best solution since you could get a much smaller and lighter bracket if switching back and forth quickly wasn't a requirement.
That looks OK. But if someone really wants to put a cinema camera (digital or film) in a nodal head that can spin perfectly on it axis while shooting, the answer is: the Oppenhiemer Spin Axis 360 Head. It comes with geared handles or can be motor driven. I've used it in a music video and it worked perfectly and smoothly. The right tool for that specific job.
The R90 looks like the right tool to put the camera easily in a 90degree mounting position for a separate shot, without having to re-rig the cam. It is much bigger than the R90 and that size and graphite structure is required to move a 40lb rig smoothly through 360degrees.
Just sayin...
Sanjin what Libec tripod are you using in the picture ? I have heard good things about the
RS-450M and was thinking about getting it for the Scarlet.
:jacked:Well, all I can say is that I can not wait till the R90 is under our Epic...
During the Chicago Fashion Shoot we mounted the Epic on a Ball Head so to have it in Portrait mode, but it was not easy for me to control the camera, so I really can't have the R90 fast in off... Jarred
More pics of it here: Epic M8 Chicago Fashion Shoot
:jacked:
Nice behind the scene photos and nice blond girl
cheers
:jacked:
cheers
