- Moderator
- #1
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
So we all know that one of the most exciting things about the DSMC system is the ability to configure the camera into an extremely lightweight "DSLR" style configuration.
I have big plans for this little camera and some of them involve a very fast and lightweight support system that can be carried over the shoulder while hiking or run-n-gun shooting. However I'm an O'Connor nut and have a hard time using most other fluid heads since I got my 2575c. There are definitely some other good heads out there but the 2575 is a standard on every film and TV set for a reason. I have also briefly owned a O'Con 1030s which was great, but undersized for full size Red One builds and overkill for DSLR and small HD cams. This began a quest for a very rare and special bird indeed, the O'Connor 515/Ultimate DV.
I had originally seen this head as the Ultimate DV head back in the DVX100 days, they were very expensive for a DV head and way beyond my price range at the time but it was really fascinating. Recently I stumbled across a 515 on E-bay and knew I had the first piece of the puzzle. (The 515 and Ultimate DV are essentially the same head but the U-DV has a control layout more like the 1030).
Next I needed a tripod as stable and smooth as the head. I wanted a range of height options from really low to really high plus a 100mm ball leveling capacity and above all extremely light weight. This meant carbon fiber for sure but it also meant a spreader-less single tube telescopic design. The final candidates were from Manfrotto, Miller and Gitzo. In the end the Gitzo GT3541XLS Systematic 6X Carbon Fiber Tripod won the day.
With a minimum height of 4" (Yes 4" not 14") and a maximum height over my head at 6.6' it can really cover all heights you could ask for on location. Here's the real kicker, these sticks weigh only 4.4Lbs! With the O'Connor 515 on top the total weight is only 12.2LBS.
I can't stress enough how smooth this little head is, and how little flex the legs have for their weight. It can counterbalance up to 18lbs at 6" lens axis and it really does have that O'Connor feel.
I can't wait to get my Epic on it and get out into the world:thumbup1:
Eric from O'Connor, you should really consider tooling up another batch of these amzing little heads, you may find a whole new market in the new DSMC users.
