Oliver Peters
- Apr 5, 2009
I would add that in the testing I've done, FCP has a very hard time correctly passing a full-swing image. I've had far better luck with Media Composer, believe it or not. Make sure that all of your sequence settings are set to RGB. Nothing 10-bit, 8-bit or high-precision YUV, if you are working in an RGB codec.
- Oliver
- Oliver
