Nils Ruinet
- Apr 21, 2007
- Paris, France
- vimeo.com
Did you try the new back-focus adjustment ? How does it work, compared to actual sytem on the Red One ?
Btw... 5k Run N' Gun Set up of the Day...
We used the Hoodman H-R 5.6 same as the one used on the Standard Red 5.6" LCD, it fits like a glove
How can you run & gun with 35mm DOF and no follow focus... I know you can just use your hand but focus is a major issue and its not like a 3/4" camera and you and your client would get pretty bored of out of focus shots pretty quickly
Hey, have you guys been going exclusively with 19mm rods?
Nice... so I should keep my 19mm carbon X rods than ;-) Plus i guess they are as light as any 15mm rods anyway.
about rods,
Does anyone knows if there will be top rods mount like on the Red One ?
Rory, we are in luck then because we will be able to select just about any sensor area and aspect with Epic.![]()
Another note for all of you geeked up for FF35 Monstros vs S35 MX is the issue of focus. Ask someone who has pulled on a 5D vs a 7D at T2.8 or lesshmy: YMMV.
Cheers - #19
These arguments about someone supposedly not being able to run and gun with s35 mm cameras in 4k have long since been disproved by thousands of us mobile EFP shooters of Red One cameras - and as of last week I shot run and gun in 5k with Epic - but somehow that's impossible? Not so...it has now been done, and will be done extensively by EFP shooters of Epic looking forward.
not least of which is using wide angle lenses or the wide end of a zoom and getting closer to your subject.
