Mark L. Pederson
REDuser Sponsor
Optimo 15-40mm - full coverage at 5K
Mark,
did the MP's have full coverage @5K? Did you also had the 18mm, does that cover full 5K?
Thanks for doing all of this![]()
Will there be an ability to window the sensor to Super 35 dimensions to ensure coverage from most PL lenses? I can see how a larger format will be handy in some instances for VFX but the resolution of the camera should still be above that of the RED One at Super 35 dimensions. I'm sure all those modes including anamorphic will be a part of future firmware updates just like 4kHD on the Red One etc....
Also remember that you can simply shoot 5K and set up your frame lines [and post crop] to any pixel resolution you desire.
This is what we're doing on Spiderman - it gives us the most flexibility.
! My emphasis added.
I remember asking about this long ago, for reasons of stabilization in post. I thought the answer at the time was lookaround cannot be recorded. So did I misunderstand, or is ability to record lookaround a new feature? And will it be available for us Scarlet Fixed run-and-gunners?
What process do you use to frame lines?
I have questions about the current EPIC camera build.
What framerates and resolutions are currently enabled?
Has any of the audio been enabled?
David.
My thinking is why have a new number that means a ratio when you could just have the actual ratio.
Hope I'm making sense
Any footage coming soon Mark?
Mark,
Can you use the 7" Red LCD with the new 5" touchscreen at the same time?
Thanks,
Bernard
...Monday he flys to Italy.
Thanks Francesco - I did some work for Cinecitta Studios so I have been to Rome - amazing city!! I'll actually be in NYC, sending two our guys with Bond for the Milan shoot - I'm busy prepping a 3D feature that rolls March 14.
Will it be shot on Epic?
