Ketch Rossi
- Jan 10, 2007
- Sardinia, Italy
- www.afroditefilms.com
To go bak on Topic here..
I like to add that for those that believe the Briese Focus system with either HMI's or Flash Tubes, are best suited
for Studio operation only, I respectfully Disagree, this is why..
I have been using them since I can remember, and when shooting outdoors on location, high end photography jobs,
see as much equipment as many medium size Movie sets, were the Briese Parabolic systems used with the Focus
line, are not more difficult to place and operate then any other HMI lighting set up when considering that no light
should be use direct, and as you add reflectors, Rags, and large Scrims, then they are just as complex to set up,
or easy, as the Briese Focus system, and wil have to respect the same laws of Physics when in windy conditions.
However the amount of control and quality of light that the Briese Focus system gives, IMO is equaled by none,
unless off course you have the need of a Very direct HArd light, then no use setting up any type of Umbrellas,
Parabolic and or Scrims to begin with, unless used for Blocking.
