David Kellermann
- May 19, 2009
- Freiburg, Germany
- www.abt-cine.de
Hi,
i was looking for possibilities to speed up Colorista 2 in Premiere Pro CS5 or After Affects CS5 to realtime but there doesn't seem to be a solution (http://reduser.net/forum/showthread.php?t=53145)
Jake Blakestone recommended to use rather an Hackintosh with Resolve than Colorista, so I did some research on Hackintoshs.
It would be great if Hackintosh users could share some of their experiences on this thread and point me and other editors looking for a good colorgrading suite on a budget in the right direction. Would a system like the following one enable a realtime workflow on ProRes Files and R3D files, even while using keyer and power masks?
ASUS P6T7 WS SuperComputer, X58
Intel Core i7-950, 4x 3.06GHz (maybe OCed)
24GB DDR3 RAM
GTX 480
Red Rocket
DeckLink HD Extreme 3D
SSD (system disc)
RAID (8x 1TB RAID0 ARC-1880-i) (all data is save on a NAS and backups)
Also has someone tried using a GTX 570 or 580?
Sorry for the many questions. I would be more than happy if someone could answer one or more of them.
David
***UPDATE***
I ordered today the following setup. I'll update this thread with news on the hackintosh DaVinci performance and some links to files and guides you will need to build your own one.
24GB 1600 DDR3 RAM
3x GTX 480 (with watercooling blocks to fit them in a single slot)
DeckLink HD Extreme 3D+
8x 1TB Spinpoint F3
Arceca ARC-1880-i
Enermax Revolution85+ 1250W ATX 2.3
Mac OS X 10.6.3
***UPDATE 2***
Thanks to Luigi, I was able to set up my Hackintosh. Everything is working flawlessly!
The components:
24GB DDR3 1600 RAM
3x GTX 480 watercooled (Aquacomputer connected via Twinconnect)
My configuration:
1 - empty
2 - empty (HMDI output)
3 - GTX480
4 - Blackmagic Decklink 3D+
5 - GTX480
6 - Areca 1880i
7 - GTX480
I partitioned the RAID0. Booting from it works perfectly (I'll set up a dual boot with Windows 7).
The read/write speeds are awesome. Aja disk test (system cache disabled) 3500MB/s read / 2000MB/s write
See this thread for further informations:
http://reduser.net/forum/showthread.php?t=54430
24GB DDR3 RAM
GTX 480
Red Rocket
SSD (system disc)
David
***UPDATE***
24GB 1600 DDR3 RAM
8x 1TB Spinpoint F3
Arceca ARC-1880-i
Mac OS X 10.6.3
***UPDATE 2***
The components:
24GB DDR3 1600 RAM
My configuration:
1 - empty
3 - GTX480
5 - GTX480
6 - Areca 1880i
7 - GTX480
