Curran Giddens
- Jan 3, 2007
- Age
- 46
- Great Barrington, MA
- www.solarsystemstudio.com
I notice that the RED Electronic FF35 lens mount wasn't in the list of mounts that will be ready to start shipping along with Epic. I also haven't heard anything about the Electronic FF35 lenses in a long time. I lost track of the latest info about them so if anyone can remember some of the different specs.
I'm still hoping that these are on track to start shipping at the end of the year. I want to have touch-focus tracking without having to buy any Nikon or Canon lenses.
Here is all the info I could find in my files:
OLED witness marks:
The idea is that the marks on the OLED screen can be changed in any number of ways, from things as simple as metric/imperial, to adding focus markers digitally through the REDMOTE.
Lots of incredible things you can do once you make lens marks a non-fixed asset. For instance, on the electronic lens one of the focus marks can be lit up, they can be "backwards," and arranged in a nonstandard linear fashion.
Auto Focus:
The focus data will be available in the .R3D files.
There is there a hold (trigger/button) type feature for auto focus to prevent it hunting when the camera and or subject is in motion. Once you quickly (auto) nail perfect focus, it doesn't alter until it's re-commanded to do so.
There will be a "generic" Canon/Nikon lens setting for lenses that are not in the database. But you should expect that lenses that have already ben profiled would operate faster / more accurately than those that have not.
There are several "speed settings" as to how fast focus works. You don't always want the fastest.
AF should be fine underwater since the it works on a pixel level, refraction is compensated for.
OLED witness marks:
Auto Focus:
I have worked with this AF a bit and I can see a few ways to use it. If you have talent that is 9' 6" away, you can tape it off and set it with your lens scale... assuming the lens and back-focus are dead nuts. Or you can visually set it with your EVF, LCD or external monitor. Or you can touchscreen it and get it dead on, then rack focus manually as they move. But you know you started with perfect focus. Really... you need to see this. Each will find a different way to add it to the arsenal. Or not. MF is always an option... just like you have always done. But my bet is that most will find a way to embrace this technology, not unlike how the still world has with DSLRs. Options are good. Trust me when I tell you this is a good option.
RED Electronic FF35 AF lenses:
Red are cinema grade with well controlled breathing. They also will cover FF35. 1st lens is the 24-75mm F2.8. There is a wide zoom and a long zoom to follow. It is smaller and lighter than the RED 18-85mm.
Focus is manual, one touch on the run-stop button, touchscreen or Pro REDmote. Single or continuous... and tracking. Also... rate control. The system is designed to work with Canon, Nikon and other programs, but will work best with RED lenses.
One big difference in the RED lenses, besides much less breathing, is the motors. They are better and faster. Our lenses will be bigger, but the difference will be clear.
This year (late) and under $10K.
