REDCINE-X Build 348...
Jannard
Red Leader
REDcine-X Build 348...
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_348_mac32.zip
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_348_mac64.zip
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_348_win32.zip
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_348_win64.zip
Change list 346->348:
Fixed: REDLine and Avid issues
Fixed: Full res decode for software exports when camera meta was set to use framing guides.
Fixed: Grade usage with the Export using REDLine option.
Fixed: Case sensitive drive issues with the Export using REDLine option.
Fixed: Panning while framing box is displayed.
Windows Avid SDK reverted back to older Avid SDK 1.5.2 compatible with Windows XP.
Fixed: additional cases where the Quicktime dialog would not show up on windows.
Fixed: FPS indicators.
Fixed: saving of the stereo setting in export presets.
FIxed: exporting of stereo clips to Quicktime and Avid.
Fixed: Timecode wrap around.
Fixed: manual distribution for Windows 64 builds.
Fixed: RGB color indicator on windows.
Optimized switching of list to thumbnail views.
Clips are now sorted by filename in the thumbnail view.
Sort order is preserved when dragging from browser to bin.
Jim
FPS indicator!!
Lots of great updates but I'm still waiting for a fix for the random image glitches I'm getting with the RED Rocket card. I reported this back to you guys almost two months ago and Redcine-X and my Rocket card is basically useless without this fix.
also when i have a lot of clips in the browser and im scrolling up and down sometimes it crashes.. is this known or would you like a log?
Please send a log to redcinex at red dot com when this happens.
That has been happening since before build 260, unfortunately. I think it's a QT bug (as in QT - the UI framework, not QuickTime).
We thought we had it nailed this time around. In addition to a verbose log file, a system crash report would be most useful as well.
~ David
We are working on finding a solution and will release it as soon as we do.
The cause/fix depends on the lots of external factors from OS version, motherboard version, other boards (pci-e load), memory type/speed, etc.
Good to know you're still working on it. The weird thing (for me) is that I can eliminate the problem by rebooting a few times until it's gone.
Tony, which Mac Pro are you using? Can you provide all of the specs?
Thanks!
Will Redcine - x ever play well with Expose and Spaces?
I personally keep RCX in space #2 and my IDEs in space #1 and it always opens in #2 as expected, even when downloaded and ran from finder.
Though if you have a use case that doesn't seem to work I'd be glad to look into it if you can send details to the redcinex at red dot com email.
This is great! Getting better all the time.
Loving 3D exports, can't wait for geometry!
On Side by Side, my initial test suggests the the left eye is exporting correctly but the right eye ignores the grade. Compare my RCX compared to the outputted QT. The left eye looks pretty close but the right is all over the place.
This is on Mac 64-bit going to QT ProRes 4444
Small Problems
Small Problems
I have 2 problems with both 346 and 348. The grade is not upgrading in the thumbnails in the bin and they get very dark sometimes retaining some stage from a grading. The viewer if I go full screen turn it to 1/2 or full and then minimize again goes black. I have to restart the software in order to view it back. These are bugs that were not existent on the 340, which I use. I am talking about mac vers. 32.
Panos
I all ready emailed you guys.
What happens is, even after assigning RC-X to a space, it will ignore that and show up in every space, and in front of other windows. It's very frustrating.
jimhare can you please email redcinex at red dot com so I can go over your workflow with you to see how you got this to happen.
