JanneJansson
Great, thanks!
Thanks, Joe. This will be fixed in the next version.When ejecting a drive from RedCineX fails, because a clip is in the player, the lower half of the browser window display format changes and becomes almost unreadable..
The good news is that the export continues...??
I've finally dumped rocketcine as my of-line rushes creating tool.
So using this latest redcinex (with Rocket) I am exporting to MXF (dnx36) for a ofline. The problem is that no matter what I do I very quickly get the OS warning 'redexport quit unexpectedly...'
The few mxf's at the beginning of the export seem alright. Can I trust this? Or shall I downgrade the Rocket drivers and go back to the trusty Rocketcine?
thanks for any lucid thoughts!
Michael L
I keep having problems with trying to open a saved project.
I save it, then when i go to open it, RCX opens, then crashes--every time.
Thanks....
Please send a report to redcinex at red dot com. Go to the Help menu, then select "Save Report..." If you can, also send the project file in question as that would be useful for diagnostic purposes.I keep having problems with trying to open a saved project.
Hi Panos,The EDL from FCP to REDCINEX works fine. After I color correct in REDCINEX how can I go back to the FCP project with the corrected files?
Panos
You could export the files as qt prores 4444 (or another format), place them in the same folder of your uncorrected footage ( keep the names) and reconect the files in FCP.
Trim is working fine except for a couple of pre-build16 clips which gave errors (first time I've tried on an old clip from 2008). Is this due to an earlier R3D sub-structure that hasn't been accounted for?
Windows 7 x64 build 340.
Paul
