Maciej Roszkowski
Active member
I have a workflow efficiency issue I'm hoping someone could help me with.
I get requests to do quick color passes (first light/ color balance type stuff) to some files that fall outside of the RedCine X workflow for me.
Essentially what I have to achieve, is a quick grade that outputs to an offline (1080/720) prores file from a source DPX or ProRes file.
Apple Color covers me in terms of the adjustments I need to do, however the problem is that the files it renders out are split up into folders and renamed, making batch jobs tedious. I'd like to be able to add a batch of lets say 20 movies and output the Color corrected versions with the same name to a different folder.
I'm open to purchasing additional software.
Thanks in advance.
Thanks in advance.
