QT proxies -- why not use Rocket and RMD?
Chris Kenny
blog.nicedissolve.com
I'm obviously not aware of all the technical constraints, but given that it's Red's code that decompresses/debayers frames to hand off to QuickTime, it seems like it should be possible to enable Rocket acceleration for QT proxies, and therefore effectively get Rocket performance in any app working with them. That could potentially be a big deal.
Also, is there any fundamental technical reason why Red's QT component couldn't take RMD look files into account when decoding clips?
Right now, QT proxies are nearly useless to us; the addition of these two features would make them extremely useful.
A QT codec doesn't know what file the frames are coming from so the codec can't find the RMD. Rocket needs multiple frames an Quicktime can't do this either.
Interesting
Does this have an implication on Rocket in Color?
Are those the only technical limitations?
You start to intrigue me seriously, in a good way! -:)
Are you implying that you have an ide on how to get around those limitations?
QuickTime supports "frame reordering" for codecs that require multiple frames (independent decode/display times) to output a single frame. For example, H.264. In principle, if RED Rocket needs multiple frames, QuickTime 7 and later can accommodate this.
I'm not sure why RED Rocket needs to know the filename -- perhaps to get the additional frames? Maybe to get the RMD file? If I knew why, I could propose a solution.
UPDATE: Here's the link to the relevant API in QuickTime (for QT Sample Table atoms): http://developer.apple.com/mac/library/documentation/QuickTime/QTFF/QTFFChap2/qtff2.html#//apple_ref/doc/uid/TP40000939-CH204-33307
If I should pick a totally uneducated guess on why the Rocket needs multiple frames, it would be that it is set to buffer a minimum number of frames before playback is allowed, to accomodate smooth playback.
But this is a total wild goose chase from a non-programmer in the most true sense of the word, based basically on how the rocket plays back...
Is there an API for using RED Rocket? How are Adobe, Avid and others accessing RED Rocket now?
Okay, I see what you're wanting here (didn't read closely enough the first time).
You could use the QT Sample Tables API to associate an "RMD" sample with each RedCode frame. (You only need one sample for all frames.)
It might even be able to make the RMD file external, in which case it might be possible to update it without modifying the QT proxy itself.
CineForm has a little helper app so you can change the metadata for the actively playing clip called SetActiveMetadata. You can read more about CineForm's ActiveMetadata stuff here: http://estore.cineform.com/products/TechNotes/ActiveMetadata.htm
UPDATE: video about ActiveMetadata here http://www.youtube.com/watch?v=LYw4S2YBvvI
Hmm. I'll fill out another one and send it in. Thanks for checking!
