Matthew Duclos
- Feb 29, 2008
- Chatsworth, CA
- www.ducloslenses.com
15mm rods work just fine if they are the right kind. Heavy duty 24" rods with a proper low-bridge would definitely do the trick. Also best to make sure that the flange is set properly on your Optimo. They are amazing works of engineering that require consistent maintenance to work properly.
