Sound ?!
OK, we have some audio pros here and we have had a great discussion on limiters and compressors etc... and we get the message about the delicate nature of sound recording and problems associated (and i for one am extremly happy with the learning available in these discussions) and i'm sure teamred will listen carefully to how they can improve on the camera but at the end of the day, workable solutions given the equation of cost versus quality needs to be addressed.
Now, there is going to be comprimises in sound production as by the sounds of it there always are. Even with the best equiptment and best ops. So there to me must be a optimal working condition given the inherent floors with technology trying to recreate reality. Red has it's own particular limitations and lets say technology itself will always have some limitations. So i'm asking you pros and enthusiastic soundphiles what in your opinion is the best solutions given the technology available under the circumstances that are available.
There seems to be two different areas,1. run and gun single or two person operation and 2. small low budget crew looking to make feature films, theatrical productions etc....
I think it is obvious that anyone with budgets higher than this will just hire a pro and let them deal with it... I think it also obvious that the revolutional aspect of red is it's ability for low budget and the reason at least 80% of us are here.
So what set ups would you employ for 1. run and gun and 2. low budget (but aiming for the highest quality, ie. the best cost versus quality ratio)
How would your work flow operate from production (and even pre production) and in post?. Give your reasoning while always attributing discusion towards the cost versus quality ratio.
Please :)
I work on the audio post of a lot of doc and indie narrative, much of which was shot/recorded by a single person, often working alone under difficult conditions. In the better cases the solution is two parts: first, they understand what is possible and keep things as simple as they can. This means as good a mic as they can afford properly mounted and windscreened on their camera (for verite) and moved off to a fixed overhead boom (for interviews, if possible). They often have a single good quality wireless channel on their other track (on 2 tr cameras), and they listen with headphones as they shoot and adjust the levels on the fly (their cameras have external level controls). They generally do not get into more complex audio than that when working alone--they don't want to be any further distracted than that (esp if they are also the interviewer). For more complex audio it's great to have help, but only if the person will pay attention and knows what they are doing somewhat. I would not try to train someone on the job--I've gotten a lot of audio that was screwed by inattention and inexperience from situations where the filmmaker might have done better on their own. There is the added burden of being cabled to a sound person, unless you can afford to have wireless links and a backup recorder rolling in case there are dropouts or other transmission problems. (When I do wireless to the camera I politely insist that the shooter wear some lightweight headphones so they can tell if we are in trouble w/ the links). Since the RED is a 4 channel device for verite work I would recommend taking two channels from the sound person (boom/lav mix) and having the cam mic on as well, esp, in wireless link or double system situations.
Part 2 of this concept is that they build in time/budget/attitude that there will need to be some serious "below the waterline" work done on the audio in post to make it all match/work and be acceptable to QC departments. There are always a few moments that can't be entirely rescued, but not too many. This has worked for us/me on many films so far, great and small. You may notice that most of the above verbiage has to do with recording audio on the camera--this is not my fave of course but it seems like most lower budget filmmakers prefer the simplicity of this approach. If you think your film might go theatrical there is a lot to be said for figuring out a workflow that includes double system audio. A colleague of mine recently shot an indie feature on an HVX w/ double system audio--they worked out a pretty efficient system involving a "laptop boy" downloading both P2 and CF cards on the set and syncing them up right there (FCP) onto drives that were then sent to post. While not always practical for many sorts of docs, this seemed like a good method for a dramatic project.
I feel like what I've said is probably too "film 101" for most people here--but I wasn't sure what sort of specific info or experience you were looking for?
Philip Perkins CAS
Philip Perkins CAS
No No... We need more kind of this communication on these boards.
Thats exactly the kind of information i was after, thanks.
Anyone else?
Also what about the idea of waist belt mixer for eng type? Sure not perfect but under the conditions might save some audio?
Hi,
I've found it always better to have picture and sound separated:
1. The soundman can pick up sounds without bothering the cameraman to push the record button. No one gets annoyed. Good sound men love to "steal" great sounds where ever they find them, any editor/director will appreciated this.
2. The camera is not tethered - in a doc-style shooting vital.
3. For non-tethered stereo on board recording one needs two wireless diversity devices, plus a third one for monitoring. The camera will be pretty loaded and bulky...
4. Syncing camera and sound recording device with for instance clockit (ambient recording) does work very well and is widely in use. No slate needed.
IMHO a Sounddevice 702T with for instance Shoeps CMC6, MK41 and one wireless diversity system is a decent basic setup that will tackle most challenges of a doc-style shoot. For decent stereo sounds a Neuman RMS 191 is very nice but unfortunately pretty expensive. There are much more affordable stereo mics out there, haven't figured that out yet.
Hans
I really don't get it. Can you state your case?
It's Apogee audio hardware. Doesn't get much better. It's a portable, multichannel mic preamp, high quality A/D/D/A conversion, soft limiting, digital & line level out, into the camera or any other recorder. And it functions as a high quality audio interface with a Mac.
What case needs to be made? :unsure:
