Shooting a bit at 700-1500 fps... Not worried since that footage will be day exteriors. Plenty of light. No flicker.
Want to shoot some interiors at high frame rates. Maybe not as high. I've heard that you need a 5k or brighter to obviate all flicker from a single tungsten source as the filament cools too much otherwise between cycles. This MIGHT be in the budget, but it also might not. 2ks would be much easier (I own two, lol). A bigger issue is that bare bulbs are part of the set dressing (potentially).
So, at what frame rate will problems begin to emerge and with what lights? 100w bulbs? 2k fresnels? Kinoflos? Electric ballast HMIs (arc wavering?).
Right now a set up might be a 2k fresnel undiffused as key, 2k through diff as fill and bare bulbs (100w per) as set dressing. Or crosslighting with 2ks through opal if that provides enough stop. Hoping to shoot at 500fps if possible. Camera will be rated at 1600 ISO. Small location, I think. Thanks.
