RED ONE POWER HOT SWAP/BREAKOUT BOX
Cliff Hokanson
Vancouver
www.cliffswebsite.com
Im selling a hot swap break out box with volt meter for $500. This allows the camera not to be shut down when the batteries are being changed and there is a lot of assesses that can be powered from the box. I use this when the Steadicam is on standby so it keeps the Steadicam batteries fresh. THERE IS ALSO A 4 PIN XLR POWER PLUG
The box has a volt meter so you always know the voltage of the battery.​
Can you plug in a VCLX Anton Bauer block to the box? Are the 4 pins to tie into the sync on the Epic? If so, please email as I'd like to buy.....stevegreen123@gmail.com
