Grzegorz Gill
- Sep 2, 2010
- Los Angeles, CA
- cargocollective.com
Hi,
I am selling my complete Red Helium Camera kit for $26,000 in Los Angeles that includes the following:
1x Red Helium 8k 60fps Body
1x Body Port Cap
1x DSMC 2 Side Handle Port Cap
1x DSMC 2 Standard OLPF
1x DSMC 2 V-Lock I/O Expander
1x Canon Titanium Mount + Cap
1x Wooden Camera PL Mount + Cap
1x DSMC 2 4.7 Inch Touch Display + cloth
1x Wooden Camera 4.7 Sunhood
2x Red 512gb Mini Mag
1x Red Mini Mag Reader
1x USB C Cable
1x Red Mini Mag 4x Slot Case
1x Wooden Camera Passthrough Top Plate
1x Wooden Camera Easy Riser
1x Wooden Camera 15mm Light Weight Bracket
1x DSMC 2 Power Adapter
2x Red Brick V-Mount 150wh Battery
1x Red Brick V-Mount Charger
1x Pelican 1510 + Dividers
I am the original owner and this was purchased Nov 2016 as an Epic W and then upgraded to the Unified DSMC 2 Body and 8k 60fps specs on Aug 2018. This camera has been my work horse since purchase and will continue to produce for the next owner op.
The camera has wear at the bottom of the body from baseplates coming on and off. The paint on the E has chipped away. Camera right side has small mark from accessories rubbing against the body like noga arms slipping. Body has no dents, never been dropped or mishandled except the mentioned scratches. Both pogo connections work just fine. I use a 4.7 touch on top, and a bomb evf on the left side. I have mounted a red side handle, and connections work as well. The rear contacts are clean and clear as I have used a dsmc2 v-lock i/o expander since original purchase.
The media mounts and works, no errors.
The 4.7 touch screen has no scratches, minimal pain chips from wear.
I am including some original boxes from Red and the entire camera kit fits tightly onto a carry on Pelican 1510.
The v-mount batteries charge and discharge normal, same goes for the charger.
Included is the standard OLPF. The OLPF has never been taken off and is clean and clear. Firmware is up to date and the black shade calibration is auto, clean blacks and no dead pixels. Also to note the camera has never been in an underwater environment or any work with lasers. I've been a red owner/operator since 2012 and I take pride in taking care of my gear. This kit will work perfectly with no surprises saving you $10,000 cash if you were to purchase new.
Operating hours as of 3.14.2021 is 1,900
Asking Price $26,000 - Location - Los Angeles
Ebay Link https://www.ebay.com/itm/333596680413
Below are items for sale only after the body is sold. I can bundle items for you as well, just let me know what you need.
1x Red Canon Motion Mount - SOLD
1x Red PL Motion Mount - $1,700
1x Wooden Camera Tool Less Monitor Adapter - $100
1x Red Bomb EVF LCOS - $650
2x LCD/EVF Adapter A - $175
1x LCD/EVF Adapter B - $175
1x LCD/EVF Cable 18 Inch - $175
1x LCD/EVF Cable 24 Inch - $175
1x Wooden Camera 12 Inch Red Male Pogo to Male Lemo LCD/EVF Cable - $175
1x G Tech USB 3 Mini Mag Reader - $136
1x DSMC 2 Universal Top Handle - $100
4x Red Brick 150wh - SOLD
1x Red Brick Charger - SOLD
1X Custom Innerspace Case
Thanks,
-GG
1x Body Port Cap
1x USB C Cable
Thanks,
-GG
