Rob Anderson
Up for grabs is a set of RED BRICK V-LOCK BATTERIES with REDBRICK V-LOCK CHARGERS in a Pelican 1600 Case w/ Trekpak Divider Inserts + the Pelican 1600 Case Lid Add-On. There are 11x RED BRICK v-lock batteries in this set and 3x RED BRICK v-lock chargers plus 3x IEEE charging cables.
NOTE: ALL OF THE BATTERIES ARE NEWER. These are the RED Pro batteries (not the older RED One batteries). All of these batteries were purchased brand-new within the last 16-months. They all hold full charging cycles. Everything is in good condition with minor wear and tear from normal use. All batteries have working cells, their original RED medallions, working pins, etc. All three chargers are working 100%. All three IEEE (North American) power cables are working 100%. If you live outside of North America, simply swap the IEEE NA cables with cables for your country -- no need to use adapters.
Pelican case is a 1600 series with Trekpak pre-cut foam inserts and metal pins. See photos. Also included is the Pelican 1600 case lid add-on for additional storage options. Case has both front clamps working and interior is in great shape. Exterior shows normal wear and tear.
RED BRICK V-LOCK BATTERIES: $370 USD EACH
RED BRICK V-LOCK BATTERY CHARGERS: $410 USD EACH
Originally paid $1,650 for the chargers and $4,950 for the batteries. Plus $190 for the Pelican 1600 with lid add-on and another $90 for the Trekpak inserts. Combined I paid $6,880 for this power package.
ENTIRE PACKAGE YOURS FOR $4,800 USD
See photos:
See photos:
