RED audio as a Quadraphonic and Surround 5.1
Andrew M.
Virginia EPIC #2441
You can process 4 RED audio channels as a Quadraphonic and Surround 5.1 in Premiere.
You export from QT to 4 discrete channels to .mov file (audio only)
Then import to the Premiere, open Surround SubMix 5.1.
Now you can map any channel to any in the Surround domain and position the image of each channel in the Surround space and in addition you can place any channel in the SubWF channel or center channel.
And you don't have to have 5-6 channel audio card in your computer.
Master will shows two channels but output could be saved from SubMix with the clip to the 5.1 and H.264 or Blu-ray format.
On the picture below you see the RED ch 3 and 4 recorded with the SM mike sound and ch 1 and 2 without any recorded sound there.
Here it is:
