RCX-P Audio syncing - 48khz question
Alex Olinger
Hi,I`ve been learning the timecode dual system auto match feature in RCX-P. I recorded my RED footage at 23.98 and my audio at 48.000 hz with a 23.98 timebase. After running automatch, in the control section of the audio tab, it shows 48khz as the frequency, but it shows 48.048 as the TC frequency.Do I need to override this to get both values to 48.000hz? Or is RCX compensating correctly already due to the footage being shot at 23.98, and I should leave it alone? I would be rendering the synced clips to ProRes with 48hz/24 bit audio attached for a Final Cut 7 project.Thanks
