Raven compression R3D + Pro Res
Naim Sutherland
I guess my search skills are failing me. I looked at Phil's post for Raven, but I can't seem to find a compression vs fps vs resolution grid.
I'm also interested to know if shooting pro res at the same time has an impact on the compression ratio you can record.
Thanks!
Thanks!
Shooting Prores + RedRaw simultaneously doesn't affect what compression ratios are available, but it does take up more recording space on the SSD.
You should be able to find the info you are looking for in the media operation guide on red.com/downloads.
