Problem exporting from Redcine
Nir Shelter
47
Sydney Australia
www.datashelter.com.au
Am trying to export shots as 32bit 4K 16/9 full process TIFF sequences from Redcine. After pressing the GO button Redcine switches the frame in the viewer with black and renders out TIFF files that are 108MB in size but only displaying black. None of the original frame is rendered out I should add that I am also printing the file name and TC onto the frames in the sequence, that information gets rendered out over the black.
I am running Redcine 3.12 on a Macbookpro core 2 duo 2.33GHZ with 2GB RAM and an ATI RadeonX1600, QT V 7.3.
I have rendered out many hours of footage to various formats from Redcine on this machine before.
Am wondering whether this is a processor issue not being fast enough for so much data to be crunched at once?
Could this be a res to aspect ration problem have all the bugs with 16/9 at 4K been solved could this be connected?
Any suggestions would be appreciated, thanks.
This is most likely due to the fact that your ATI card does not have a big enough frame buffer to handle the output size.
Best,
Lucas
ASSIMILATE, inc.
LA, CA, USA
