No mirror box - No shutter
E.J. Sadler
Active member
www.blueworldstudios.com
The mirror and shutter are legacy mechanical components that cause a number of issues with DSLRs.
As much as I love a good optical viewfinder, there are plenty of times when it falls short - medium distance low DOF wide angle, tilt shift, low light.
I have no doubt that at the rate display technology is improving, a fully electronic viewfinder will be as good, or significantly better than an optical viewfinder. Zoom in to check focus, focus assist, light level boost for low light, and the coolest - a detachable remote viewfinder.
I shoot all the time with the camera away from my eye, it would be nice to retire my Jedi framing technique and actually be able to see what I'm getting.
Without a mirror, you could have access to the great wide angle rangefinder lenses that don't deal with the optical compromises of a large flange distance. But of course, with such a low flange distance, an IMS would still allow you to use any just about any glass out there.
Although no mirror box would allow for a smaller physical size, I have a feeling that space will be used for heat sink/cooling systems.
Loose the shutter. The RED has shown that there is no need for a mechanical shutter. We shoot enough that all of our bodies are on their third or fourth shutters. Not that Canon shutters are cheap, it's just that 3-4K images a week wears them out. I could live without having to replace the shutters, and without having to deal with the inherent dust issues.
Also, no shutter could mean significantly higher flash sync speeds. Using flash to knock daylight down a few stops always has some issues. You can't shoot higher than 1/250th, so you either need to shoot at F11, or stack the NDs. Either way, you wind up needing a boat load of power. Battery powered studio strobes can do it, but that's a lot of weight to carry around all the time. Canon's high speed sync will sync up to the maximum shutter speed, but since it's multiple firing the flash to follow the shutter slit as it passes over the sensor, you loose most of your power. High speed flash sync coupled with low flash duration flashes would allow you to create imagery that just isn't that easy or even possible to do today.
The other great thing about losing the shutter would be a zero noise stealth cam. Combine this with a detachable viewfinder, and you could shoot without anyone even knowing they're in the image. We already use a RED just to shoot stills in noise intolerant environments, it would be great to have something a little smaller and stealthy.
When does the reservation list start, and how many can I buy?
Iris and seeing...
Iris and seeing...
I think if the lower res electronic finder has a 1:1 zoom button, maybe with a pan joy-stick for the center of the zoom area, you do not need an optical finder.
Optical finders are hard to use with the lens smaller than f/5.6 for movie work anyway, and with the high speed of the sensor the light coming through an optical sensor is too low to see well.
I think people forget, than open iris metering cannot let you see while shooting movies mode, the lens needs to stop down.
I made some other posts about viewfinder issues and mirrors a few days ago, you can click on my "more posts" thing to the left to read them...
i totally agree. with todays lcd or even oled technology an evf would be a lot better than an ovf.
you could even drop the standard 3'' lcd on the back and offer an optional detachable screen x) 'cause the screens on the back are imho pretty bad for reviewing especially in bright sunlight. An evf though would be pretty much uninfluenced by bright sunlight.
I'd love no shutter for high native flash speed sync. Looking at work like Patrik Giardino and Justin Steele controlling ambient light is so important when shooting with strobes. As for the sound and the clunk,though I'll miss it, I'll take no shutter for and no camera shake any day.
you can always have a digital shutter sound like all the p&s out there x)
All great ideas which I hope are incorporated into the RED still camera. And the idea of a short film plane to lens mount distance with an interchangeable mount is fantastic. Let's not forget however that Leica is having lots of problems with their M lenses with a digital sensor because the distance is too short. So let's stick with SLR or movie lenses which seem to work better with sensors.
I have only owned one camera with a digital viewfinder in the Leica Digilux 2. It worked great other than the issue of blackout after exposure. It would freeze the viewfinder image for review for a few seconds as we see in the rear LCD's of SLRs now. That was a big problem. The last thing a shooter wants is an interrupted view of what he is shooting. The review should be sent to the rear LCD and keep the viewfinder live all the time. That would be fantastic.
Can't wait to see what's coming. Please give your RED users a first shot at these Jim!
