Need some Help with a LEMO connector
Kyle Gentz
Fresno, CA
www.motionpicweddings.com
So today's shoot got cut short due to my Switchtronic V-Mount lemo connector was damaged, not sure how, but I figure a case shut on it. Does anyone know if i can replace this end? Need help so i can get back up and running ASAP.
Temporarily can it not be bent back with a pair of pliers? I am sure you can replace it thought but I do not know where you'd get a connector.
I think you may be able to buy the outer shield as a separate part and change it without disturbing the inner core with its wiring and pins. There will be stamped on the plug body, a very small part number. That thought may not hold good if the damage means the plug body cannot be dismantled over the core. I think you are showing good sense not wanting to risk damaging the panel socket on the camera body. That is a much harder and inconvenient job to fix.
http://www.lemo.com/defaultwidgets.asp
We have spare connectors in stock if you need. It looks like just the front barrel is damaged, which in that case you can replace, but their is a special wrench used to unlock and lock the connector, so you may want to send it in to us. We can waive the labor.
Otherwise, you need to grab to pairs of pliers, but you will most likely scratch the connector up pretty badly.
PM or email me.
PM or email me.
Email Sent
Need LEMO FGJ.1B.306.CWLD72Z DC input connector. Just a connector itself.
PM me please if you now where I can get it w/o waiting for 3 weeks as here:
mouser.com/ProductDetail/LEMO/FGJ1B306CWLD72Z/?qs=sGAEpiMZZMvNQHCitdfR%252bOoYqrLxdJSI
