Marshall 7" HDMI Monitor issues
Marq Lee
El Segundo, CA
Hi there,
We have a Marshall LCD70XP-HDMI monitor tethered for the AV and after pressing the 1:1 on the 5" Touchscreen, some glitch happens with the signal. A BAND appears at the bottom of the Marshall Monitor. Any additional pressing of the 1:1 on the Scarlet simply keeps adding another band on the Marshall.
Has anyone had any similar issues with any other monitors tethered via HDMI.
Note: This is a 720p monitor and been properly enabled.
Thanks guys.
Marq Lee
Hey Matt,
Yes. It works just fine. You have to make sure you enable the HDMI in the settings/Audio-Video...
Again it works perfectly fine...just as long as you don't press the 1:1 (Button 'C' on Side Handle) on the camera. Once we did that, this band thing happens.
A bit odd. I guess no one else is having this issue that has this same monitor.
Marq
I was trying to use that same monitor the other day on my Scarlet but I couldn't get an image. I went through all the settings but nothing would work. Did you at least getting something out of the camera to the monitor?
I had the SDI version of the same monitor and ran into some similar issues (though it ended up being camera related). Can you post a picture of what the band looks like?
