jacob.schwarz
- Jun 23, 2009
Part 4 of our on going blog series on HDR is up.
http://www.mysterybox.us/blog/2016/10/20/hdr-video-part-4-shooting-for-hdr
Excerpts:
It’s important to realize that, in general, all footage is better in HDR, regardless of its age or how it was filmed. That being said, there are things you can do while filming to best prepare for an HDR finish.
If you’re using a prosumer or entry level professional camera, taking a few preparatory steps to set up how you’ll actually be capturing the image can mean the difference between getting footage that can be used in HDR mastering, vs. footage that can’t.
In summary, when choosing your kit for HDR, consider:
16 bpc > 14 bpc > 12 bpc > 10 bpc > 8 bpc: 10 bpc should be your minimum spec.
RAW > LOG > Linear > Gamma 2.4: avoid baking in your gamma at all costs!
Camera Native / BT.2020 > DCI-P3 > Rec. 709 color primaries
RAW > Compressed RAW > Intraframe compression (ProRes, DNxHR, AVC/HEVC Intra) > Interframe compressed (AVC/H.264, HEVC).
As for the technique, consider the following:
- The goal for HDR shooting is to expose your whites to eliminating clipping the RAW data when possible, and minimizing it when it’s not. Stop down or use ND: protect your highlights and avoid clipping like the plague
- If you’re planning on using a PQ/SMPTE ST2084 HDR mastery workflow, you’ll need to assume that most of your deep darks are in fact visible, beyond what you’d normally consider available.
- When you shoot for HDR, you can’t assume that every consumer display will be HDR. So you need to consider that how the darks and lights will play in both HDR and SDR.
- The overall dynamic range of the scene needs to be planned in a way that the super bright / HDR elements are restricted to a small portion of the overall frame, so as to not push up the frame average light level.
- Because of the expanded darkness range of HDR, you can design much more ‘dark and moody’ lighting setups than you normally would for standard film or video exhibition.
Follow us over to our latest blog post for more details, at http://www.mysterybox.us/blog/2016/10/20/hdr-video-part-4-shooting-for-hdr
Excerpts:
