Gamma shift from After Effects - PLEASE HELP!
AnthonyFaust
Washington, D.C.
www.anthonyfaust.com
Hello everyone,
I am working with 4K RED footage from the RED ONE camera. Here is my workflow. I have Premiere CS4 with the RED plugin that allows me to natively import r3d files and edit them. I brought an r3d file into my Premiere timeline. I exported it as an Uncompressed YUV 4:2:2 movie. I then compared the original r3D file to this Uncompressed file. There was a slight shift in the luminance but I figured that was because it was going from r3D (which is RAW) to Uncompressed.
Next, I brought in the Uncompressed file into After Effects. I did NOTHING to it. I simply put it in a comp, and then exported it back as uncompressed 4:2:2. When I opened up this AE file and compared it to the Uncompressed file that I had exported from Premiere Pro, it looked noticeably brighter. It shifted the gamma, even though I maintained the same size and codec.
There has to be a solution to this problem. What can I do to fix this?
Thanks,
Anthony
Check the bit depth of your after effects project - depending on your version AFX can introduce a gamma shift if the project bit depth is lower than the footage bit depth.
Thanks John, but that didn't work. After further tests, I found out that the color shift only happens if I actually view that file in QuickTime. But if I import that AE file back into Premiere, and then export it out, it doesn't shift. It's weird. I think the solution is to just upgrade to CS5 so I can edit the r3D file natively in AE CS5.
Any other ideas you can share, feel free to do so.
Thanks,
Anthony
The problem is actually Quicktime. Quicktime has a tendency to screw up the gamma of video. Adobe managed to work around this within their apps so you get consistent results when importing and exporting between the Adobe applications.
hummmm.. Quicktime for PC?
