Freeze frame issue progress?
zerogravity
Is there any progress with Redcine Freeze Frame Issue (RFFI)? I know we can follow the rules by RFO. But If there is a demand for export hours of footage to say QT DV-PAL for offline, we really need to have a chance to set up project to PAL first and then resize footage to it, instead to do resize just on output. It's way too slower and time is very important there.
And will there be 25fps interpreting of 25fps footage fixed in near future? Any footage is interpret by Redcine as 24fps now. It is very annoying to changing one by one now.
Thanks for any answer
Jaromir
From what I've been told: do not mix different resolution footage, do not mix different fps footage; keep it all the same.
Also your system specs have a lot to do with it; using fast drives, using a RAID 0 as opposed to using a system drive. Inputting and outputting to a Firewire drive...etc. If there is a bottleneck, you should try to take care of that.
