Error Decoding Frame in Redcine-x Pro v9 with Red Epic footage.
Richard Sanchez
New member
I've got 5k Anamorphic footage shot on the RED Epic, I'm trying to use REDCINE-X PRO to create mxf media for Avid. I've set my framing to Width 2x, I'm transcoding to DNx175 10-bit (because there isn't a ton of footage), and I'm using the Mitchell software scaling preset. I've successfully transcoded one roll, but all rolls beyond that report "Error Decoding Frame". I can view the clips in the entirety within REDCINE-X PRO. I realize that doesn't necessarily rule out the possibility of corrupt clips, but that leads me to believe it might be more of a software issue with REDCINE-X PRO. I've tried REDCINE-X PRO version 8 and version 9. Tried REDCINE-X Build 506 (both 32-bit version and 64-bit version), I have tried transcoding on two separate systems and tried to transcode the clips directly in Avid Media Composer 6 via AMA. I've even created disk images of two of the troublesome rolls and ran REDundead on them, but that didn't yield any results. Any advice would be appreciated!
