clipfinder avid xml problem
Yann Bouzerand
When i try to import an XML from avid to clipfinder, nothing happens, no clips are imported, what it the correct method ?
regards
If you send me the xml I will take a look. What process did you use to create the proxies ie. metafuze, redrushes, clipfinder etc. and how did you import the accompanying ale? Do your clips in the bin show the original r3d names in the filename, camroll and tapeID?
hope I can help
noel
When using FilmScribe XML, it dumps all metadata on clip if there is one available. User cannot select which fields as with other template formats. Everything goes.
Michael
