Cinekinetic Jib-O’Connor 50D Fluid Head-Peter Lisand Tripod-Dolly
Rik Nielsen
New member
Cinekinetic Jib has a 55” reach & telescoping arm. Bought new & in perfect condition except for scratches.
Peter Lisand Tripod. Shows external wear but perfectly straight & spreaders are excellent.
O’Connor 50D fluid head (claw) has no leaks & has the base plate included (not shown) with a 3/8”mount. I’ve drilled & tapped ¼” x 20 holes in these older plates before on other setups I’ve had that have worked perfectly instead of buying a whole new plate. I took it to Transylvania Film & TV in Burbank & George there said it was in good condition but he could feel minor slight play in the pan. We put it up against a rebuilt 50D while I was there & the tilt was very good although he felt it could be better with a rebuild. If I had not tested it next to a fresh rebuild I would have said it was perfect but that’s why I went over there.
Dolly with ¾ ply seated in angle iron.
I’ve owned this setup since ’94 & was used mostly with the old Betacams & has been stored in my home & rented out occasionally including a couple of Red owners.
My shooting days are over as my eyesight isn’t what it used to be so I’m letting everything go for $975. If you wanted to go for the whole 50D rebuild even though I personally think it has a lot of use left in it before that’s needed Transylvania will do it for $650 in 5 days.
Thank You
Rik Nielsen
Los Angeles area
shotworx@socal.rr.com
