Build 11 issue
Greg M
Digital FX
Louisiana
www.digitalfx.tv
BUILD 11
Viewfinder
When I select METER in the viewfinder menu and select a meter (say FOCUS ASSIST).
I can turn this on/off by pushing the first button on the LCD (this is great)
But, if I hold the last button to switch to HD/SDI monitors- this action enables the METERS as well...which you dont want to happen since you cant see the full menu.
Holding the last button should not enable the checkbox.
TEMP SOLUTION:
The workaround is you either hit the first button on the LCD
again (which still functions even though the LCD is off) or hit VIDEO button on back of camera which brings up the menu- (which is not visable in the HD/SDI monitor so it effectively removes FOCUS ASSIST from the HD/SDI monitors.
