Michael Tiemann
I've been wrestling with some wide-angle decisions over the past few days, and came to the conclusion that I'm not really looking for a wide-angle effect...I just want more of the room going into the camera. On a sound stage this is easy--just move the camera back until you get the perspective you want. In a conventional room environment, you are constrained by the four walls (or in my case, six, because the room is hexagonal). It occured to me that I might be able to back up the camera by shooting across a mirror, and for less than $5 I was able to get a super-cheap door mirror (48" x 12") from Wal*Mart to begin investigating the possibilities.
I found that for my application, there are places I can put the mirror that send the image and perspective I want to a place that doesn't appear to conflict with other camera placement requirements, nor does it conflict too much with the function of the room itself. Indeed, I can "step back" about 12' further from my subject than without the mirror, meaning I can be 20' away instead of 8'. More importantly, I can be 13' away from the closest object in the scene rather than merely 1'. If you do the math, the relative size ratio that derives from a distance ratio of 13:20 is much less extreme than a distance ratio 1:8 ! Moreover, I'm really stuck with only one position without the mirror, but with it I can creep forward to get a pleasing mid-point, such as a distance ratio of 5:12.
That's all good...if the mirror is up to the task. The $5 mirror I got from Wal*Mart is not optically flat (nor even optically clean). I see that this company supplies the mirrors used in cooking shows:
And we all know that cooking shows use only the highest possible production values. (I say that only half in jest--some cooking shows really do have great production values, and it's a fact that food finished in 4K tastes much better than film that's only shot in HD.)
I have attempted to search for other references about this technique, but have come up empty. Do any of you have experiences using mirrors to break down walls to get better perspective in your rooms? Are these mirrors really good enough to shoot through/across?
