3d stereoscopic workflow help
Felix Desjardins Audette
Active member
Hey guys, I have a small stereo project...
Whats your post prod workflow ?? what programs are you using ? im a adobe fan, cs6...
Thanks for your help
felix
I think it should be premiere with one eye->EDL out->then speed grade can auto load both side. After auto match and grading, render out then back to premiere and made some zoom to cover the black edges from the auto match(why SG do not do that kind of zoom? Or I missed some thing?), final render, you got two video, you can also combine them with SG to one video (Side by side or up/down or interlace...).
My current problem is why speed grade load EDL always get a "frame index out of range" error? It's on a pirated version CS6, so maybe not SG's problem, I will buy a copyright version after I assemble my workstation. Another question is why SG seemed do not support HDRX which is very useful?
hey Zhang,
Heres a cool pipeline ive found on speedgrade for s3d
http://forums.adobe.com/message/4549205
and I think for your EDL to work, you need to strip audio and every vfx in your timeline... it wont accept it otherwise...
Cheers
felix
Thank you Felix. EDL problem seemed almost solved after I attached a TC generator to the EPIC, it looks mainly about timecode thing. I will made more test later to confirm that.
