Does anyone know if it is possible to make a long cable (i.e. 12mts/36ft) for the LCD, to use it with a jib? I own a Jimmy Jib apart from two R1s, and it would be great to fit it on the operator´s end... it becomes almost useless in that situation.
Guido
