White Spots in Black areas
Johnny St.Ours
48
www.piraeushd.com
I shot a horse race last weekend and I'm having a major problem with the footage. Everywhere in my frames where it goes deep black, I get this white speckled noise all over
I can look at the clips and adjust them in any one of the following:
Redcine (old style)
RedinceX 221
RedAlert
FCP
In these programs the r3ds and proxies look fine, but as soon as I render the proxies or log and transfer in FCP, they get spotted like this. When I rendered from RedAlert, RA quit on me, when I rendered on either Redcine, RedcineX or Redrushes- they just reported an error and created nothing.
Build 30
Any ideas?
QT wrappers?
QT wrappers?
I've never seen this before, but 90 percent of the time, any problems I have viewing or rendering my R3D files can be easily solved by recreating all of my Quicktime wrappers using Red Rushes.
I'd give that a shot and try rendering again.
It looks almost as if the deepest blacks are the only values that are dropping out. Is this happening after a color correct? Could it be because you have your black level's floor set too low?
Thanks for the reply, Jake- I've never seen it either
I'm trying a DPX now, and so far it's working- after that I'll give making a whole new set of wrappers a whirl
I thought about that color correct issue, too, and although I have played around some with look settings, both of these stills are from camera settings only.
had that after a firmware upgrade 30 some beta
solution:
1. bring the blacklevel to a normal state with redcine
2. you have to render from redcine full debayer
3. use color and get shure that you use full 4k render settings
4. the rendered files ( 422hq ) looked fine
5. upgrade the firmware to 30 final
solved all here
here for additional qs
