Beta REDCINE-X (Build 221) & REDLINE (Build 194)
am i supposed to do something with the new redline i just downloaded. i dont think i ever downloaded redline in the past i just downloaded rocketcine or redrushes etc and just opened them up and used them. does the new redcineX v2 need me to do some other kind of install with that redline zip for it to work properly?
This version was a preview release. The release version will have an installer.
Finally getting back to playing here. Took REDCINE-X 221 for it's maiden flight. It seemed to be working great. Then it locked up (no beachball mouse cursor) and wouldn't respond after I attempted to copy a look to all the clips in the bin for the second time. I had to force quit.
No log files were written that I can find. But I'll keep playing with it.
Sometime next week. We've got some good feedback on 221 and need to work on a few things before we do another release.
Thanks, Deanan. We're a bit excited over here, just took possession of our first RED One.
ok ive been playing with the new redcine x on my new i7 system :) but im trying to export a small 10 second clip. i set up all my settings in the export block and click export. it says running but nothing is happening. my cpu sits at 0% load. i try to pause it, stop it, anything and it crashes. Im exporting to 4k quicktime files. This is my first time using this program. sorry if im just being stupid lol.
k good news i just tryed some other settings and it rendering. but another question. its only using about 30% of my cpu and 2.5gb of 6gb of ram. Is this normal? i would expect it to be using around 85% and 4.5gb.
uh oh i just experienced the same problem as the other guys. Fuzz with a large black bar at the bottom. time to try for 1080p
Same thing here, the drop down menu won't work after the first change.
I had the same problem after going fullscreen - the thing is it DOES work, but you have to guess where the setting you want is and click on it. The drop down menu is invisible but still active!
This bug was also in v194.
But still a massive improvement and a nice piece of software.
Well done Red guys :thumbsup:
Can anyone comment on where things stand with XML or EDL support, for creating cut-downs of full .R3D files prior to transcoding... or loading "telecine" XML lists generated by Crimson. I recall Red was going to add support for this a month or so ago, but leaving it up to 3rd party developers? Can any one inform further?
here is my solution to the conform xml
http://www.youtube.com/watch?v=EBVvM1ThGoU
(just me and my iMac after the kids had gone to bed!)
it's available fer nuthin
it is ugly and terminal/cmd centric but it seems to work for me.
it's all done at 25 fps but i can change all the 25's to 24 for you cross atlantic folk!
all the source scripts will be available so if you make it better post it back yeah?
have fun
there are other (mac only) solutions
http://www.reduser.net/forum/showthread.php?t=42478
and
clipfinder
I think there's another one as well somewhere...
mine you can mess with.
j
have fun
and
clipfinder
j
Thanks for the links... did you post the source scripts someplace? Have you tried this with FCP by chance? The source scripts are preset to work in 25 fps, yes? How easy is that to change, on a per project basis?
scripts
scripts
the stuff is all open there
they are .command files which are basically a double clickable script
if you drag it onto textedit it will open up
just copy it and change the 25 to 24 then use that when you need to! Easy peasy.
the windows one is just a .bat file and the xsl it uses is just a text file. all doable by someone who knows what they are doing (or me.)
one thing of note you HAVE to use redcine-x and relink to the ale it makes to get your rushes done or the xml won't have the required information in it.
and if you're on the beta of MC version 5 and messing about you need to change TapeID to TapeName in the script as that has changed in filmscribe (thanks avid!)
I've not done anything with FCP. Clipfinder works for that no?
this stuff is just or avid.
cheers
j
Thanks for the info. Do you know anything about the Redcine X for windows? Your post said later this week. Is it out and if so where I can down load it? thanks.
PROBLEM - Viewer does not play the full clip length. (build 221)
playback with redrocket card and output to external monitor via HD-SDI thru AJA converter and input via HDMI dreamcolor monitor:
ISSUE: when loading clips and playing them back, they do not play all the way till the end. The play head will show that it is at the end of the clip in the viewer, but the clip has not played to the end. If i then drag the playhead slightly to the left, i'll see part of the shot that is way ahead of where the clip stopped. So, playhead basically is not showing current location or viewer does not play the full clip.
An updated version of RedLine is what I've been waiting for!
I can't seem to get it to write QT wrappers -- using -w 10 seems to start to render full res quickTimes & doesn't do the wrappers. Is this a bug, or is the documentation wrong?
Chris
It would appear to be a bug. -w 10 worked fine in the last REDline, but doesn't in the new one. Have you reported this to Red?
