Good Practice
PatC
NY
Hey Guys,
I thought it might be fun to have a thread about "good practices" if this is a repost than sorry, but if not might be a good read! Everyone add one...
here is an example-
Always eject drives before powering down the camera.
Shoot 1/2 less stop exposure that what the goalposts and/or common sense tell you, then bring back highs in post. This gives more precise post-control of falloff and better maintains highlight saturation.
And from a RED/IT point of view, whenever the budget allows redundancy is paramount, backup bodies, backup DIT stations, backup everything you can afford to.
Always check what build your on- undo+joystick...
This is priceless Pat!
I always wondered how to determine the Build installed, when the camera is running. This helps a lot. GREAT!!!
Oh, and if you are a DIT you want to make sure, that you have a uninterrupted power supply unit. Because there is nothing worse than someone pulling the plug, when you are right in the middle of downloading some files :emote_hanged:
Delete the files after confirmed transfer, never format a magazine with files on it.
If you get rid of just the .profiles this will make the card unformatted in camera, but the media still readable on your machine. I do this as a safety in case for some reason I need to get back to a card before it is shot again...
Also, try to cycle your media appropriately, go through all your media before repeating.
When prepping for a shoot, always go to the maintenance menu and reset LOOK, USER, and SYSTEM.
If you don't know the cameras usage history and/or you just updated the software build, do a black balance as well.
Then go through your checklist of parameters and set them for the job.
"undo + system" goes right back to the last menu page you were at. This makes you work very fast (ie. when change the varispeed setting back and forth)
If you finish a job and you give back your media to the rental house, make sure you overwrite it with zeros, if you don´t want the next guy who picks up your drive to see all of your footage when he´s running redundead over it.
But only do so after you triple checked, that you have copied everything!
Once you overwrite your footage it can´t be retrieved!!!
