Build 30 Clean monitor output?
Jeff Brown
London, UK
Chaps
Having not had a chance to play with build 30 yet can anyone confirm that the HDSDI outputs now is not affected by false color/magnify etc?
Or am I misreading that? I also thought that was a processing restriction....
I'm away from a camera at the moment so I can't check to confirm this, but I believe the clean output refers to being able to remove the greyed out overlay from the look around area so you get a "clean" image.
False color/magnify definitely still come through on Build 30.
Clean Feed selection on RED ONE
As Sam says, it's still going to reflect false color processing, but it does allow you to suppress all graphic overlays ..
Can you please tell me how you can suppress all graphic overlays on the HDSDI I have been reading through the manual and can not find it.
On Build 30.5.0. Access SYSTEM / SETUP / PROGRAM then set FEED to CLEAN
Has anyone ever tried to chart what the actual resolution is coming out of that SDI? Is it 8 bit? 12 bit?
