Wil Klassen
AJA HD 10C2 Dual Rate Digital to Analog Video converter
Lightly Used in Like New Condition. Comes with the original power adapter, HD10C2 Module, Component Video adapter and SVGA adapter.
Asking $400.
The HD10C2 is a signal converter that decodes a digital High Definition (BNC) Video signal to an analog High Definition (13W3) Video signal. This device comes with a breakout cable and features a miniature size. The featured upgrade is the ability to accept standard SDI and convert to YUV, RGB and composite.
- Breakout Cable
A breakout cable utilizing the 13W3 connector breaks out to 5 BNC connectors enabling an RGBHV interface.
- Loop Through
This unit offers two looping HD-SDI outputs enabling other conversion applications and signal passage.
- Computer Monitor Display
This unit enables a High Definition video signal to be displayed on a multisync SVGA computer monitor.
- Dual Rate
For HD-SDI inputs, the HD10C2 outputs full bandwidth HD component or VGA-style RGBHV video. For SDI inputs, component or composite SD outputs are supported.
- Multi-Standard
NTSC and PAL analog outputs are supported.
- Compact Size
Measuring less than six inches long, this unit will fit into small studio spaces or desktop applications very easily.
Input
Digital HDTV: On a Looping 75 ohm BNC connector
- 1080i @ 50 to 60 Hz
- 1035i @ 50 to 60 Hz
- 1080p sf @ 23.98 to 30 Hz
- 720p @ 59.94 Hz
SDI Standard Definition, Looping, SMPTE 259/292/296, on BNC connectors
Output
Analog HDTV:
RGBHV on a breakout from 13W3 Connector
Standard Definition:
YUV and RGB or Composite with or without sync on a breakout from 13W3
Two Looping HD SDI or Standard SDI:
On BNC connecters
Conversion
Digital HDTV or Standard SDI to Analog HDTV or Analog Component/composite
Control
External Dip Switch
YUV or RGB
Component or Composite (SD)
SD Pedestal
SD Blanking
HD 4:3 Graticule
SD NTSC or NTSC Japan
Sync on Video
Power Source
5 VDC from an Optional Power Supply
Dimensions (WxDxH)
3.1 x 5.8 x 1"
14.7 x 7.9 x 2.5cm
Weight
1 lb
454 grams
Any questions please feel free to ask!
Asking $400.
- Breakout Cable
- Loop Through
- Dual Rate
- Multi-Standard
- Compact Size
Input
- 720p @ 59.94 Hz
Output
Analog HDTV:
On BNC connecters
Conversion
Control
External Dip Switch
YUV or RGB
SD Pedestal
SD Blanking
HD 4:3 Graticule
Sync on Video
Power Source
Dimensions (WxDxH)
3.1 x 5.8 x 1"
14.7 x 7.9 x 2.5cm
Weight
1 lb
454 grams
