Batch Render with RED Alert!
Brett Putman
New member
So, I have been told that I can do a batch render with RED Alert!, but I cannot figure out how to do so.
Can someone point me in the right direction?
Thanks!
You can, but in RedRushes, using the settings you made in RedAlert.
When you open an R3D in RedAlert, RedAlert creates an RSX file in the RDC folder the R3D is in. You tell RedRushes to transcode using the settings you created in RedAlert by changing the Render tab settings to "RSX" instead of "Camera" in the "Look Source" menu. You can either select one RSX setting for all the clips, or use the default "Clip RSX" setting , and it will use the individual RSX's in the RDC folders that you created.
Does RedRushes come with RED Alert!?
I cant seem to find it anywhere online.
Sorry for the silly questions, but this is the first time I have worked with RED footage.
Yes it does come with RedAlert, it is an independent, stand-alone program that should have installed itself on your system drive when you installed RedAlert.
I already used clipfinder to do try and batch render and the color was WAY off when I took a look at the newly rendered files.
Did I just miss something or what?
Strange....
