Where is the Full debayer/Half debayer option?
Jason
Active member
Hi,
I'm wondering where can i find the option in redcine x for export?
I have no idea what option i'm currently using at the moment.
Is the tab under the detail settings the one ?
from Window select Export Tool, then you can select EDIT next to the Export button and that opens the EXPORT SETTINGS window, which has 'Debayer Settings' under OUTPUT RESOLUTION
Hi,
Thanks for the input, Im currently using build 96 RedcineX for Mac, the Debayer option is not in the export settings. Any idea?
Yes, but just want to check, if I were using build 96, I need to know what's the setting that we have exported our footage.
Any advice?
Build 96 didn't have the option.
Nick thanks for the info.
So if thats the case, is the footage rendered out of Build 96 full debayer quality?
