Heads up for FLUT aware Clipfinder/ROCKETcine-X
Kaku Ito
65
Chiyoda-ku, Tokyo
www.dittok.info
Heads up for people using the Flight Director & ROCKETcine-X combination.
The FLUT aware Clipfinder Hans sent us does not seem to work with the in/out from the RSX on the Flight Director, when you render in ROCKETcine-X, it won't recognize the in/out points.
Just use the older build for this. I reported Hans about this already.
I had that happen to me too, and reported it to Hans. He couldn't replicate it, and when I tried to neither could I!
I guess it's one of those annoying intermittent bugs. One to watch out for though, and I'm sure Hans will get to the bottom of it.
Hello Nick,
I made sure restarted it and did everything to fix but it didn't fix unless I go back to the older version.
Hi guys,
I have tried again today but could not reproduce the problem.
If anyone has the same problem it would help me greatly if they could do the following
- check the RSX files in the alias folders and see if the in/out-points are in there
- if correct in/out-points are in the RSX files, please send me the RSX files.
- if there are no in/out-points, please let me know how you prepared the clips in Clipfinder
Hans
Hi Hans, Where can i get the Flut enabled clipfinder? i don't see it on your site.
Thanks!
Hi guys,
Hans
I have a noob question. I'm unfamiliar with Flight Director. Is this a tool that allows a FCP to be imported into REDCINE-X?
